raindownthunda
I'm excited about it, but also nervous to a certain extent, I'll feel better when a few people have built it successfully
Yeah there is some flexibility to change parts, depending on the part.
I used a chassis cutout for the RCAs that should fit quite a few different brands, so the builder could choose what they like there assuming their chosen RCA fits.
The potentiometer is a little bit tricky - it has to be a 20-25K pot maximum given the high Miller capacitance of the input stage, otherwise there will be high frequency rolloff. The source impedance of the pot must remain low, 20-25K max ensures that it is. HOWEVER, some ladder type pots, like a TKD, have a higher source impedance than your typical log taper potentiometer, even if they are 20-25K, so I would not recommend using them.
The input stage bypass and coupling capacitors could be changed assuming they fit on the board. But, IMO, I would not recommend changing the bypass caps. I did extensive A-B testing of audio grade electrolytics for the input stage, the Jupiter Cosmos caps were far and away the best, I think using something else in that position would be a step down in performance. I designed the PCB around Jupiter copper foil 0.22uF 400VDC coupling caps, but you could certainly use a different cap in that position as long as it meets the spec and fits.
Dave at Landfall, who makes the chassis, can do different powder coating finishes, so that could be coordinated with him. I will say though that I cannot guarantee how any specific coating will turn out, some powders coat better than others in my experience.
Any change that would require altering a mounting hole in the chassis would need to have the CAD files modified. I'm sorry but I am not likely to volunteer my time to do that for each individual request, but someone could ask Dave at Landfall if he is willing to make the changes for them.
There is a switch to change taps on the output transformer for changing the output impedance to suit different headphones, also using different output tubes will change the output impedance to a minor degree. In general, higher transconductance outputs will result in a lower output impedance and vice versa.
Thanks for the detailed reply! I was mainly trying to get a sense of how much this would be a “modders” amp vs recommend sticking with the spec was designed. I fully trust you’ve done so much experimenting that the parts selected are already as good as it gets. It’s helpful to know what components you’d recommend leaving alone vs where there is some user choice based on preference. Definitely would be unreasonable to expect you to field custom tweaks to chassis, PCB, etc. It‘s already incredibly generous of you to share this design with the community with the goal of making it as easy as possible to build!
