Aegis DIY Tube Headphone Amplifier
Mar 12, 2023 at 8:50 PM Post #166 of 192
miter53
Oakland, CA
Any possibility of seeing the BOM for this?
Mar 12, 2023 at 8:52 PM Post #167 of 192
L0rdGwyn
Member of the Trade: Amp Builder
Cleveland
BOM, instructions, etc. will come out together when all the materials are done.
Mar 12, 2023 at 9:26 PM Post #168 of 192
goldwerger
NYC
Mar 14, 2023 at 3:08 PM Post #169 of 192
martelanc24
Hi @L0rdGwyn, I have been following the thread since day 1 after seeing the review from Monsterzero. I am really considering building this amp in the future if chasis availability will not be a major problem here in Europe.
I would like to ask a question about daily runtime. So excluding tubes, would it be any problem running the amp continuously 8-10 hours per day (maybe 4 days per week), or would you recommend limiting ON time to a certain number of continuous hours? Room temperature would be arround 20°C (68F) in the colder months and 25°C (77F) in the hotter months.
This is how I have been using my DIY tube amplifier for the past year, without a single issue. (The amp is single ended EL84 + 12AT7 with solid state rectification, components soldered to a PCB, not point to point.) Degradation might be faster, but I like to use the equipment I build, that is why I am asking. Thank you.
Mar 14, 2023 at 7:16 PM Post #170 of 192
L0rdGwyn
Cleveland
Hi there - no issue running the amp for a long period of time other than the lifetime of the tubes. Some power tubes (e.g., 6V6) and some rectifiers (e.g. 5Y3) will be run closer to their maximum ratings in this amp, which is fine, but they may wear out faster if run for prolonged periods of time, so I'd probably recommend using tubes that are not biased very hot for long term use, for example EL34 outputs and GZ34 or 5R4 rectifier. All interior components are properly derated.
Mar 15, 2023 at 2:50 PM Post #171 of 192
martelanc24
Thank you for the information and explanation. It will help a lot with chosing tubes for my type of use. If I end up building the amp of course.
Mar 15, 2023 at 4:06 PM Post #172 of 192
Metaldog99z
US
I'm planning to build this, and I have ordered the Lundahl iron - lead time is about 6 weeks (end of April). I am looking to get the tubes I will need for the build.
I already have a pair of EL37s that I will use - any thoughts on ECC35, 5691 or other compatible 6SL7 input tubes? I see RCAs and Mullards in the pics, and would like anyone with knowledge of these to provide thoughts.
Thanks!
Mar 15, 2023 at 11:59 PM Post #173 of 192
JazzVinyl
Thanks!
I use an amp designed around 6/12SL7 as driver. I think you will find that
6SL7 differs from 6SN7 in that the SL7's sound more alike than different.
Tube brand "house sound" is still apparent but you won't get vast sonic changes
when changing driver tubes when the amp is designed to use SL7.
I love my $5 RCA clear tops from the mid 1950's. Have that "just right"
response throughout the entire FR.
Most SL7's have round plates. There are a few flat plate SL7's. To me, they
have greater clarity in the mids/highs but are not as thick on the bottom as their
round plate cousins.
You might also find the currently produced Russian 6SL7 round plates (the "China" branded ones appear to be these, rebranded) are pretty good too. They are the opposite of the flat plates...they are deep, thick and somewhat moody. There is a Melz equiv that looks a lot like the Russion tube in construction but appears to have a different kind of metal for its round plates. It is a good preformer too.
There is a current production 6SL7 "Tung Sol Brown Base Flat Plate" that is made in Russia, so Tung Sol in name only, but after a few hours of burn in, I think you would like these, too. Well worth their cost.
The good thing about SL7 is that you won't need buckets of cash for great sounding drivers.
I am excited for your build and I can hardly wait to hear your opinion of the Aegis!
Mar 18, 2023 at 12:37 PM Post #174 of 192
Tom-s
I've been in touch with Dave from Landfall systems. And he's a very friendly guy to work with and super responsive.
Here's a link to their website to get some impressions: https://www.landfallsystems.com/
First have a look at the website to find a color/finish that fits your setup. Having an anodized chassis was about 70$ extra over powdercoat colors.
Shipping to Europe was 65$ for me.
His packaging is great and all panels got to me without any scratches in no time.
Pictures below for inspiration with packaging and sides showing. The color is casper blue powdercoat. Inspired by all great Landfall chassis builds from @carlman14: https://www.head-fi.org/threads/carls-diy-adventures.957646/page-2#post-16548412
Edit: Further more I need to add that apart from the looks; the quality of the finish has been very durable in my opinion.
Mar 18, 2023 at 12:47 PM Post #175 of 192
ScornDefeat
NJ/NYC
Their website seems to be in-progess with little info; do you know if they offer engraving on the chassis?
Mar 18, 2023 at 12:56 PM Post #176 of 192
L0rdGwyn
Cleveland
Yes they do. Dave has made several chassis for me, he is fantastic, ask him for some photos and he will show examples. After my doing some at home powder coating, he got inspired and spent some cash on a much better powder coating setup making mine obsolete lol now he coats everything too, a one stop shop.
Mar 18, 2023 at 4:27 PM Post #177 of 192
bcowen
North Carolina
Nice! I really like that color.
Mar 22, 2023 at 6:04 AM Post #178 of 192
caryking
North Carolina
Output Z on the low setting with EL34 is 5ohm, on high Z setting 17ohms last time I measured. I would recommend low setting for 16-120ohm, high for 120ohm and up.
It should be able to run most any headphone well. The most demanding headphone I've tried with this amp is the Susvara. I thought it sounded great but I'm not a Susvara amplification connoisseur. We should have another opinion on that pairing soon.
I know we discussed impedances; however, I’m still struggling understanding this…
what output transformer are you using?
what are the taps on them?
then, what is the understanding on impedance matching? Is it all about having enough wattage, for a given headphone impedance? Also, is it about the the damping needed for the headphones? How do you know what the damping factor is?
