NelsonVandal
- Aug 27, 2006
I wanted to try one of the new super spec'd opamps. I never could tame the AD8099's, but these little chips work with no hassle. DC offset -2/7 mV, very low noise, no audible oscillation, no hum. I use them in a Mini3 configuration (same resistor values except there's no output resistors, active ground, TLE2426, ferrite beads on the output). Panasonic FC's, Sanyo OS-Cons, low ESR tantalums and ceramics for decoupling. Absolutely no feedback traces, 0 mm, SMD 805 resistors soldered directly to opamp pins. No feedback caps (not even in the ground channel), maybe I should add some 2 pF like suggested in the data sheet.
Powered by 7 AAA's 1000 mAh for decent battery life, packed in a Hammond C801 with a trickle charger.
Sound is good. I have to burn it in and listen some more. The sound is very close to Mini3 (not burnt in either) i.e. AD8397. Quite forward sounding. Not the same bass slam as AD8397, but that opamp has more slam than anything else.
