Rednamalas1
- Jan 12, 2008
I have not unfortunately, as leather pads are quite expensive for some reason. And I had no problem with stock pads
Originally Posted by bowraboy /img/forum/go_quote.gif Kermac, Did you like the MS-2? |
Originally Posted by bowraboy /img/forum/go_quote.gif I think you should go the Pro. The MS-Pro while having a similar sound is very different from the MS-2, bigger soundstage, smoother (hasn't got that harsh treble) and nice bass with not quite as much impact. I got rid of mine after I acquired a pair of K701s but ended up missing them to much and bought another pair. I have owned the AD900s, K701, DT860, DT440, MS1 & MS2 and still have the DT531, DT250 and Pros. The MS-Pros are definitely my favourites and I am not getting rid of them. |
Originally Posted by nickchen /img/forum/go_quote.gif The AD2000 can be a beast and it has apparantly quality issues. The one I tried had a worldclass bass, but awfully coloured mids and veiled highs. However, one of our german AT believers compared this AD2K to his exemplar and the two differed quite noticeably (his AD2000 did not sound so strange). So beware, if you get a "bad" one, you might end up quite frustrated. |
Originally Posted by synaesthetic /img/forum/go_quote.gif My AD700s also shipped with one pad thinner/flatter/squishier than the other one. While I don't notice much of a change in sound when I perform the fatpad mod, I do notice that the addition of material to the "flat" pad prevents it from rubbing my ear raw. I've reversed the fatpad mod on my AD700s because the material I used was making the pads too stiff and uncomfortable immediately, as opposed to the raw ear shell after hours of wear. I guess I'll find something else that's not quite so stiff to use. |
Originally Posted by Henmyr /img/forum/go_quote.gif @ Clinical. I've read Marcus posts about this too and have then tried to hear this from the AD2000, but I really don't. It's very immersive and musical. I've read that the "AD2000 does not let you analyz the music, but instead forces you to listen" and this is very much true to my ears. I find it very hard to really describe the sound of the AD2000 to people who have not heard it. The DT880/990/HD650/600/K501 are all very similar, and if you've heard one you can at least think you know how the other sounds. The AD2000 is a bit like the Grado sound, if you haven't heard it you can't really imagine it, but with AD2000 I find it's even more so. |
Originally Posted by Kernmac /img/forum/go_quote.gif Has anyone used SA5000 with an amp of similar capability to my Corda Move Porta Corda III with good results? Or Should I forget the SA5000 and just focus on AD2000 or MSPro? |
Originally Posted by third_eye /img/forum/go_quote.gif The SA5000 is faster, more detailed, cooler; the AD2000 is warmer, romantic, airy. I think it comes down to the type of music you listen too. The SA5000 would be better for faster music, electronica, metal............ |
