3 playlists that I created on the player itself, all 3 of them do not produce any sound when the 3rd or 4th song starts to play. The files are PCM FLAC.Could you provide a little more information please? Is it the same playlist all the time? Different playlists? Playlist you created on the player itself? Is it all PCM FLAC or DSD also in the playlist?
ACTIVO P1 Digital Audio Player - Coming Soon
- Thread starter JasonNYC
Richard A
Thanks Jason.Yes it is. The update last night was that it will not be available until the end of November. I do not know why it was delayed further other than that is the new availability date.
I have not heard of any issues. I will share this with the team and also do some testing this weekend on my own to see if I can reproduce the issues you are having.3 playlists that I created on the player itself, all 3 of them do not produce any sound when the 3rd or 4th song starts to play. The files are PCM FLAC.
Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
thankyouboss
A month later, any updates on this?Confirmed this issue will be fixed in a future firmware update. Currently do not have an ETA on when the fix will be available.
Meanwhile I got into another issue, just bough 1TB SAMSUNG EVO microSDXC card from Amazon and P1 says "This device doesn't support this Samsung SD card. Tap to set up in a supported format". Of course tapping it doesn't do anything, and I can't find anything related to SD cards in settings.
FAT32 is the recommended formatting for microSD cards in the player. To format in the player - Settings -> General -> System Information -> Erase SD Card.A month later, any updates on this?
Please note, anything that is currently on the microSD card will be erased.
thankyouboss
Oh, that's where it was, thank you, still it's grayed out for me and does nothing, tried restarting the player and plugging the card in and out. (And I don't have an adapter to do it on PC yet)FAT32 is the recommended formatting for microSD cards in the player. To format in the player - Settings -> General -> System Information -> Erase SD Card.
- Mar 5, 2012
I LOVE the design. I'm sure the sound is excellent. Hope to try it at CanJam Dallas.
@JasonNYC - The Qobuz app cannot read the offline files downloaded to microSD cards while working fine with the internal storage in offline mode. I did a format of the SD cards with the P1, I tried different SD cards ((SanDisk 512GB and Samsung 128GB), I reinstalled the app, I tried older version of Qobuz (8.1.1) I returned the P1 device to factory settings. Nothing worked. Other apps have no problem reading from the SD cards offline, Only Qobuz does not work. Please advise.
rlw6534
The P1 has clear issues with scoped storage (SAF). It seems impossible to give proper access to the SD Card. I'm surprised and curious that other apps work.
Just tested on my P1, was able to download 12 different tracks, various bit rate/sample rates and from different albums/artists to a Samsung 128GB microSD card and play back offline without issue. Since you are having no issues with other apps, I assume you may not have granted the permissions to the Qobuz app on initial install to access the microSD card.@JasonNYC - The Qobuz app cannot read the offline files downloaded to microSD cards while working fine with the internal storage in offline mode. I did a format of the SD cards with the P1, I tried different SD cards ((SanDisk 512GB and Samsung 128GB), I reinstalled the app, I tried older version of Qobuz (8.1.1) I returned the P1 device to factory settings. Nothing worked. Other apps have no problem reading from the SD cards offline, Only Qobuz does not work. Please advise.
In the app drawer, press and hold the Qobuz app icon and select app info. Please insure Files and Music permission is on.
Files and Media permission was already on.Just tested on my P1, was able to download 12 different tracks, various bit rate/sample rates and from different albums/artists to a Samsung 128GB microSD card and play back offline without issue. Since you are having no issues with other apps, I assume you may not have granted the permissions to the Qobuz app on initial install to access the microSD card.
In settings, under storage, you are able to select SD Card and the app allows you to download tracks to the SD card, but you cannot play them or do you not have the option to select SD card as download location? If you are able to download tracks, does the app show used storage under downloaded music?Files and Media permission was already on.
It does show as downloaded.
I tried Tidal - Same problem
