ES_EF
Hey @ES_EF, I don't have my pair with me ATM, they are with @grizzlybeast. This is by memory, but I agree, the HD800 didn't have enough bass, especially sub bass quantity to fully enjoy movies. I think the AR-H1 does a better job. I also find the AR-H1 to have less fatiguing treble than the HD800 because the HD800 treble spike is at 6kHz which is hard to tame, the 10kHz peak of the AR-H1 is less offensive, creating air and a more lively sound, which can be mellowed out with a warm amp.
The sound stage of the AR-H1 is really impressive for a planar. One of the best that I've heard, and as I've said it's due to the similar dip around 4kHz as the HD800. Hard left and right sounds will not be as in front of you as the HD800 but it's not much different.
Also, here is an update:
I received a replacement sample since I found that the left side's lower bass output was caused by a weak seal with the pad and the cup. Here is the updated frequency response of the new AR-H1:
Average of first AR-H1 with leaky left pad in Red, Average of the second AR-H1 in green:
thank you, this is immensely helpful
placing a order tonight
these seem to check a lot of the right boxes
btw ill be getting their earpad mounting rings replicated/ 3-d printed for sure
ill post my results here
