overlunge
- Jan 27, 2005
Hi Teerawit,
There is no covering underneath the vent holes. But Chris does recommend you to cover it if you don't use dAck! for awhile, not while it's operational.
Hope that helps,
Overlunge
Originally Posted by Teerawit I can't help but notice that the Ack dACks have see-through holes on the top. Is this covered by translucent material to protect the internals? What kind of material? |
Hi Teerawit,
Hope that helps,
Overlunge
