AC adapter for use with Burson Audio HA-1060DS DAC/Headphone amplifier
Jun 8, 2012 at 6:45 AM Thread Starter Post #1 of 5
nosracl
Hello all.
Having just received my new Burson HA-1060DS in the post, I have suddenly realised that it's got a 2-pin AC plug instead of a UK 3-pin.
Obviously, I'll need to find an adapter. My question is: what kind should I buy, and which one is safest/best for the Burson amp? I don't want to plug in this £400 piece of kit for the first time and blow it up!
Thanks in advance for any help.
Jun 8, 2012 at 7:40 AM Post #2 of 5
If you are definately keeping it just cut the plug of and replace with a 3 pin UK plug. Black lead is live in the US if I remember correctly.
Aug 7, 2012 at 9:23 AM Post #3 of 5
Universal Ac Adapter
Universal AC adapters are devices that convert supply power from an external source to electronic equipment through a converter connected by copper-wire cabling. Archer manufactures a line of universal AC adapters that can be purchased by individuals for general use.
universal AC adapters have a visible switch for selecting different voltages, and the adapters come with a set of connector tips. Usually, an AC adapter is built to last for years, but sometimes it does not last as long as planned. When caring for or replacing a faulty AC adapter, there are a few things to keep in mind in order to maximize its usefulness and compatibility. Before you buy ac adapter, better you read thing you need to know how to get the best adapter. want to read just visit - Universal Ac Adapter
Oct 12, 2012 at 9:51 AM Post #4 of 5
An AC Power Adapter is an electronic device which produces a specific direct current from the mains with an Alternating Current (AC). Although actually a power supply it is popularly known as an AC Power Adapter or AC Adapter. Laptops along with most other portable devices use Direct Current (DC), this also applies to rechargeable batteries which power laptops. Direct Current has a constant flow of electric charge in one direction and flows from low to high potential. Connecting a laptop to AC is unsuitable and dangerous due to the varying magnitude and direction of the current, which can cause an internal component to fail and even result in fire.
This is a particular design of a power adapter which accepts DC input and output DC voltage required to power a laptop. Instead of a standard plug for a wall socket, these have a specific cable that plugs in the cigarette lighter. The 12V DC supplied through the cigarette lighter socket is converted to provide a different DC voltage. This power adapter can also be used in other vehicles with similar sockets i.e. Vans, trucks and even boats. Air or airplane universal ac adapter work in the same way.
Dec 3, 2012 at 8:07 AM Post #5 of 5
Universal travel adapter allows one to charge up his/her gears. In different countries different types of converters are used. But the universal ones are made in such a way so that people can use it anywhere, despite of which country you are heading for (100V-250V-50/60Hz). This is probably the reason why the Universal Travel Adapters are so popular. This article will introduce two types of universal adapters and their functionalities. In electronic good selling stores, people will find several types of universal adapters. Some of the newest products among them include "Universal Travel Adapter With USB Port" and "Universal AC
People who travel a lot love to use it because it allows to connect different types of plugs to one side, and thereafter by turning the knob selector, a wide variety of plug blades come popping out from its other side. The size of this universal adapter is small enough to get fitted to your crowded suitcase. The price of this product is also reasonable -around $17. More information how to find good and cheap universal ac adapter from this site
