mbwilson111
- Oct 13, 2016
Wow those drivers look much nicer. Not going to open my black one to look...
Don't open them if you don't have to. It's absolutely PITA to keep them from falling apart. Need monk-like zen to gently pry open the shell and tape up the driver immediately to handle them safely. I've been putting off fixing a batch of broken ones that my boy killed; not looking forward to that job.Wow those drivers look much nicer. Not going to open my black one to look...
more like panda dexterity and zen focus!
I suppose it was good luck that the grey one with the bad driver broke, instead of the black one.but that failed with the grey one....
I have the same problem with Monkey...Look for PK2 shell...are perfect for me.Can you suggest some smaller enclosures or enclosures with different shapes because Monk + and other earphones using same shell (probably MX500) do not fitfit well and tend to fall out because my ear opening is smaller.
BTW, youyou h truly said that these forums are dangerous. A year back i accidentally came across a post here telling about Monk+. I was allured and bought one, got the addiction and now have at least 15 earphones and iem, 4 USB DACs, 2 Amps etc. And the most dangerous side is, once you discover some nuances in your favourite track while listening through these earphones, which you never heard before in your main midfi system, you start craving for a more capable Hifi system thereby draining more money. In fact this happened to me. Anyway, I am enjoying this hobby with a renewed zeal.
Regards
Partha
I have the Faaeal Snow-Lotus 1.0 and I love them. They're warmer and have more bass than the Monk+, with a little more rolled off treble, but still lots of detail.I have a VE Monk+ and I like it so far but unfortunately build quality of it is not the best and it will fail in a next few weeks probably.
At this point is there anything new that can replace the good old monk or should I buy Monk+ again or do you have another suggestion ? My budget is extremely limited for earbuds, lets say $10 incl. shipping.
There are people suggesting "Faaeal" brand. What do you think of it?
I just received the Faaeal original batch today, they sound great
Here you go, final option on this link:I thought my google-fu was strong but it's failing me. I'm trying to find a variety pack of foam covers, if they exist. Normal foams, thin foams, and donuts. Multiple colors would be great too. I thought I read somewhere that VE sells something like that, or at least sells thin foams but I'm not having luck. Anyone know where I can get some?
