Absolute best budget earbuds?
- Thread starter Tayyab Pirzada
DJ The Rocket
i am confused by this impedance thing.. 300 Ohms means they are not likely to reach their full potential in normal everyday smartphones and laptop sound cards?
At 300ohm and 95 sensitivity, it shouldn't be properly driven via normal smartphones. There's the possibility, but it's unlikely.
The 300 ohms part isn't the problem. *IF* you can get to the volume you want, 300 ohms is an easier load to drive than 30 ohms, due to the much lower current demands. 300 ohms is much more forgiving of high output impedances as well. It's just down to the volume question.
The main reason not to use a regular smartphone is simply that the sound quality is usually terrible on them. The main flagship phones these days tend to be respectable at least, and actually quite good at best.
@seanc6441 Have you considered an XB10? They're perfect for the V20; apt-x HD sounds indistinguishable from the V20 headphone jack, provided you're listening to lossless files. MP3s of course will take a SQ hit through the recompression, but even TOTL earbuds tend to be forgiving of this. I'll often stream Soundcloud over to the XB10 and I rarely mind the quality
I didn’t like the cold signature of the v20. Detailed but not very natural to my ears. Also the soundstage is quite narrow.The 300 ohms part isn't the problem. *IF* you can get to the volume you want, 300 ohms is an easier load to drive than 30 ohms, due to the much lower current demands. 300 ohms is much more forgiving of high output impedances as well. It's just down to the volume question.
This is low impendance mode.
waynes world
- Jun 21, 2012
I think that sean is probably getting sick of people recommending bluetooth receivers to him - I know that he's sick of me doing it LOL!
Anyway, I've heard good things about the XB10. I instead went for the $70 Fiio BTR1 (4.2, aptx), and I have been very happy with it. I am now very intrigued with the Radsone Earstudio which will retail for approx $100 (5.0, APTXHD, balanced output, 14 hours battery life, excellent SQ from what I've read, etc etc).
i almost forgot about this, but have you tried the IFI Ear Buddy? it really does work when i listen to spotify on my phone and tablets
although using it with my Earstudio doesn't improve anything, it even make the sound too smooth.
i definitely recommend them for using it with phones
the XB10 is on par with the Earstudio. can't really go wrong with either of them. i just like the earstudio better (better form factor, cheaper)
Saoshyant
I live the XB10. Works flawlessly with my G6, and has enough driving power for my needs.
DJ The Rocket
Has enough driving power for ANYONE'S needs
That little hockey puck can drive my extremely inefficient Alpha Primes respectably well in balanced. Maybe it wouldn't do well with an HE6, but then again maybe it would.
DBaldock9
Can the A&K XB10 be used as a USB DAC, the same way that a Radsone EarStudio can?
Seems like that could be a handy feature, if your music playing device doesn't have Bluetooth aptX HD, but does have USB output.
I don't think the xb10 can. The earstudio can be used as usb dac on pc and phones, and can also set to disable charging so it will not drain the phone
DJ The Rocket
I emailed A&K this very question right when it came out. The answer that was relayed from the engineers was that it wasn't possible. That may well be true, I haven't had a reason to take mine apart yet, but I suspect it technically would be possible if you wrote your own firmware a la Rockbox!
waynes world
- Jun 21, 2012
Huh! That's pretty slick too. That thing seems pretty impressive, especially for the price.
Headroom vs ry4s. Anybody have both to compare?
if i am not wrong Ry4S after burn in already is better than the EMX500..
theoutsider
The Unboxing Video of Lypertek Mevi In-ear Monitors/ Earphones (budget Chi-Fi)
kiler
- Mar 26, 2011
Cool stopmotion, ETA for the full review?
Majin
- Dec 16, 2010
People talking about the RY4S, is it the version with the UE cable? or are we talking about this one?
https://nl.aliexpress.com/item/RY4S...19a8-44dc-854f-e524b9b1b1a0&priceBeautifyAB=0
