golov17
@David Mitchell
more neutral, better for ear monitoring, i think..
That looks like it should work well, as long as everyone is wearing a belt, to clip it to. [...]
For the Personal Monitoring System - will it be a single console, with multiple headphone amplifier outputs - or will it somehow be distributed so that the individuals can actually control their own mix and level at their location?
If it's going to be "centrally located & controlled", then you might want to see if those belt/body packs are available with a local volume control (attenuator) inside.
@David Mitchell
friends, do you know where to buy Shark ear hook for earbuds like Vido, Ty hi-z hp32 and VE MONK? I'm looking for but can not find. Is there anyone selling on aliexpress or ebay?
Hi friend, I did not find this model. Could you post the link?
I thought people would mention the KZs here
Too many people don't make the distinction between IEM and earbud (calling IEM's earbuds *rolls eyes*) thus you get genuinely confused newcomers talking about IEMs.Do they make earbuds?
I like my Panasonic HJE125's (Ergofit). Probably because they are the only earbuds that I have tried that actually fit my ears well. The others that I've tried that are just circular shaped are either too tight or too loose and they don't block outside noise sufficiently. The sound quality is decent compared to other inexpensive in-ear earphones I have tried, with a wide frequency response.
