Hi guys, find the volume 1 too loud for me using 2.5 balanced Solaris SE on Sp2000. Any suggestions?
about Volume on Sp2000 using Solaris SE
- Thread starter qhnaaa
- Tags
- solaris solaris se sp2000
IFI IEMatch could be an option but I don’t know if it will affect the FR / tuning! Some people reported that with andromeda but most thought it was ok!Hi guys, find the volume 1 too loud for me using 2.5 balanced Solaris SE on Sp2000. Any suggestions?
I see! Thank you Ill tryIFI IEMatch could be an option but I don’t know if it will affect the FR / tuning! Some people reported that with andromeda but most thought it was ok!
MightBeAlon
Member of the Trade: nlovell audio
Ifi make two versions of IEMatch (3.5mm and 2.5mm). If you're using a 2.5mm balanced output you'll need to make sure you pick up the IEMatch2.5 rather than the "normal" IEMatch
I see! Have u tried IEMatch before? If so how’s the product? Will it affect the tuning?Ifi make two versions of IEMatch (3.5mm and 2.5mm). If you're using a 2.5mm balanced output you'll need to make sure you pick up the IEMatch2.5 rather than the "normal" IEMatch
MightBeAlon
I've not used it personally, but there are plenty of reviews here on Head-FiI see! Have u tried IEMatch before? If so how’s the product? Will it affect the tuning?
Thx a lot!I've not used it personally, but there are plenty of reviews here on Head-Fi![]()
