about the Denon DCP 150
Jul 31, 2006 at 3:16 AM Thread Starter Post #1 of 5
TNND
Hi,
Could someone tell me what is the input voltage of the AC-DC adapter, is input 220Volts or 110Volts, I know the output is 6Volts, and also do you know where to buy the Denon DCP 150 accessories like remote, case and manual? Thanks a lot!
Jul 31, 2006 at 3:36 AM Post #2 of 5
TNND
Is there any other type of remote which could replace the original one, so I can get one on ebay
Jul 31, 2006 at 7:24 AM Post #3 of 5
DanT
It's a simple wallwart so it depend on where you buy your player. European player come with european wallwart, US player with US wallwart, but it's the same player so "input" voltage depend on the wallwart.
The remote model is RC-236 not sure which if any is compatible with it.
