Would you say it was a difficult build? |
Not exceedingly difficult: the process of assembly was similar to any other through-hole board. However, the density of parts on this board is significantly higher than in most amplifiers, which leaves out several luxuries present in other builds. For example, part labels are small almost uniformly under parts, making verification of correct placement sometimes difficult, and the connection points for inputs, outputs, and switches are in somewhat odd locations when compared to the nice terminal blocks that you would get with a SOHA II or Millett Hybrid. I made one transposition of parts during initial assembly, which required desoldering and replacing four transistors, and as mentioned above I had some issues with the prototype circuit which should not be present in the final build.
On the plus side, there are no adjustments to make, and casing, the weak point of myself and many others, does not require the precision needed for amps where headphone jacks and volume potentiometers are integral to the board. Overall, I'd say with few reservations that anyone who has previously completed an amplifier of moderate complexity should have little trouble building this. From your sig, you've been making CMOYs- has that been going well? Have you had problems with any that you managed to successfully debug? If you're confident you can run through assembly and do basic debugging (ie, multimeter measurements, desoldering parts) then I'd say go for it.
