- Dec 14, 2012
Is there any other way to get uapp on m11?
Tried with M11 to update, google folder put In SD. How do you update exactly. I opened the local update and the folder but don’t see a button to start the update.
You mean buy UAPP through the Google Play store on your Android mobile? And then extract an apk from it? And after that install it on the Fiio using APKPure? If so, why need the firmware update to enable the Play store on the Fiio? Btw, I don't have an Android phone. So I can't get UAPP on my Fiio? Even with the Play store installed? Because it does not show up in a search.Working uapp 5.4.7 versión!!!
You need to buy the app on your mobile, use apk extractor and install it in fiio m11.
Enjoy!
that is, I made the purchase from my Android mobile to have the license linked to my Google account later with apk extractor you get to recover the installation file and by bluetooth you send it to the cold you install it and you run it the services of Google and the Play store It is necessary because you have to be able to activate a Google account in your cold but the license cannot validate you and the program will not work for you.
Can anyone validate that an app like Qobuz or Amazon music is actually playing at variable high resolutions?Unfortunately, the firmware is misconfigured in such a way that the Play Store thinks it does not support USB host mode (which is a requirement for installing the app). Please ask FiiO to correct this.
Furthermore, we have purchased a M11 PRO recently and tried to get the HiRes mode working. Although we got it to work partially, it does not seem to change sample rates, so we sent an email to FiiO. After a long time they replied, but nothing came out of it yet.
If you know of other apps that can do HiRes on the FiiO (other than the FiiO Music app) and know a bit on ADB, then please let me know.
You can install UAPP however by this link:
http://www.audio-evolution.com/priv_downloads/USBAudioPlayerPRO_5.4.7.apk
(although you wouldn't receive the full quality)
UAPP themselves have said they have not been able to get M11 Pro to switch sample rates in HiRes. So it might be playing, but you’re not getting the HiRes you think you are.Dear friends,
First of all, from the horses mouth: latest UAPP extracted as Mithrandir1980 instructed above works as supposed on my Fiio M11Pro. No hi-res issues whatsoever. Do as instructed before reading all the marketing bs floating around on the internet
On the same problem: the firmware patch should be put on the SD card as downloaded (zip file) DO NOT extract the folder.
Another example, UAPP shows MQA green/blue light on Tidal streams in the interface, but you know it’s not unfolding because FiiO hasn’t enabled third party MQA support yet.
