A few my DIY projects
  1. jororaitchev
    I want to show you how I find the volume of the rear speakers.They have a complex form and the introduction of data in the appropriate program will take a long time, after assembling of the cabinet i do additional processing and here the math does not help.
    From waste material I made this gadget ,that takes part in the measurements and when assembling the cabinet:
    I prepared the two shells in this way;
    I fill the cabinet with water to the red line / there ends the front panel with the speakers /.
    I find the volume - 43l, I deduct the weight of the internal ribbed - massa 3.4kg.
    And the net volume of the cabinet is 39. 6l. More than I need, I need about 32l.
    The problem is that my investor likes the vision of the column.The decrease in volume must occur inside the construction of the cabinet.This sends the project in a more initial phase,we have a new requirement for the project, second W18 EX001.
    chinsettawong likes this.
  2. Pars Contributor
    I concur with a previous poster's assessment... Holy ****!
    Very nice job, and thank you for the construction documentation which you provided! You do very fine work!
  3. jororaitchev
    Thank you for your attention!
    Everything starts from the beginning;
    After processing the internal ribbing, I can start assembling the cabinet; new pr3.jpg new pr4.jpg
  4. jororaitchev
    I will continue publication to show the finish this project;
    I made the filter compartment for "ТW" and "МW", Bass section will be in the cabinet.
  5. jororaitchev
    ..and more;
  6. jororaitchev
    ..and more;
    The first home tests are very good.
    My current surround speakers of " Technics" CA-10 with a good sound from 1997, they are sadly retreated himself ...
    Technical data:
    Frequence Range; 33-25000 Hz
    Long term Max Power; 200 W
    Crossover Frequency; 2800 Hz
    Impedance; 4 Ohms
    Sensitivity; 90 db SPL
    Cabinet Volume; 31 L
    Gross weight / without stand /; 27kg.
    This is the project of the rear speakers, will finish it with "Bird's eye view". There will be a sequel ...sometime..
    Joro Raitchev
    Sofia- Bulgaria
