9v battery holder
post-159363
Thread Starter
Post #1 of 8
Fenster
I am building an outboard battery power supply for my portable amp (porta corda), and I can't seem to find a 2 X 9-volt battery holder for purchase anywhere online. The thing is, I would like it built for series connection (for a constant 18v power source). Any tips for sites that carry this sort of thing?
Thanks
post-159439
Post #2 of 8
JMT
JMT Audio:PPA/META42 Amp Factory
Moderator
If you haven't already, try:
Digikey Electronics, Newark Electronics, Mouser Electronics
I have never seen dual 9v holders. Sometimes, if you go search out of the way electronic stores (not the Shack), you can find some aluminum 9v holders with snaps and solder terminals. I found some at a small store that specializes in surplus parts.
post-159464
Post #3 of 8
aos
May one day solve the Mystery of the Whoosh
JMT is right, and I also think Digikey sells PCB-mount 9V connectors. Something like that is used in Airhead I think? You could make a small PCB (or not even a PCB) and mount two pairs of those to create a dual 9V package. Too much work though.
post-159468
Post #4 of 8
puppyslugg
I purchased some dual 9v holders from Mouser, but they are in parralell. I used two dual 9v holders in a series/parralell config.
post-159477
Post #5 of 8
andrzejpw
May one day invent Bose-cancelling headphones.
so that's 18V, right?
post-159490
Post #6 of 8
puppyslugg
Hi andrzejpw
That is correct. 18v into a meta (cha47, cmoy) with the virtual ground, etc. will give you +-9v. I used it in my jmt/cha47 with ad8610's.
post-159509
Post #7 of 8
puppyslugg
Hi Fenster,
After looking at my dual 9v holders from mouser, I think you can modify them in a series config. You'll need to snip the metal strip and rewire for series. BTW, this dual 9v holder's top is exposed, so you may need to insulate.
post-159536
Post #8 of 8
Fenster
Thanks for all the help everybody, I hadn't heard of any of those parts retailers before. I think I'll go for the dual holder from mouser and reconfigure myself as puppyslugg recommended.
Thanks again.
