Wuhtzu
- Mar 7, 2012
Hi everyone
I own and really love a pair of Sennheiser HD595 headphones. The only problem is that they terminate in a 6.5mm jack connector and I use them mostly for my computer, mp3-player and so on. What I do right now is to use an adapter cable like the one made by Grado (http://www.divineaudio.co.uk/headphones/headphone-accessories/grado-adaptor-cable-6-3mm-to-3-5mm-15cm-length-/prod_724.html), but I would like to get rid of it and just have a 3.5mm jack at the end.
I see two options:
#1: Get an replacement cable with a 3.5mm jack on and simply replace the cable the way it's meant to be. Maybe a cable from one of their other headsets will work or similar.
#2: Solder on a new 3.5mm jack connector.
Does anyone know if #1 is possible - does a cable terminating in a 3.5mm jack exist which will fit the HD595?
Or can anyone recommend a good 3.5mm jack connector which I can "simply" solder on? My problem with this solution is that none of the jack connectors I've found have a cable protector matching the diameter of the HD595 cord. So it will look stupid and and the attachment will not be optimal.
Best regards
Wuhtzu
I see two options:
Best regards
Wuhtzu
