Originally Posted by wafflesomd /img/forum/go_quote.gif
So my current portable amp is running off two 9 volt betteries.
Does it need ~ 18V? If not, what does it need? If you haven't determined the minimum voltage threshold yet, it might be a good start.
Is there anyway, or any battery out there that can take the place of two 9 volts. Or anyway I can power the amp with some else, I'm trying to fit it into a smaller case. |
Sure, how about 1 x 9V? I think everyone would like to just make everything smaller if there were no negatives involved. Any way you look at it, if you keep the same battery technology and reduce battery size, you approach a result of having to give up voltage or runtime or both. It is not always true but switchers are not always as efficient as we'd like.
While going with fewer cells means less redundant waste on the container aspects of a cell construction, if you have to step up the voltage with a switcher, that alone entails space for the addt'l board, development time and cost, potentially addt'l noise enough to need further filtration.
As noise frequency goes up, a typical opamp PSRR goes down, a lot. Think of it as the frequency of the opamp operation, not the audio frequency, that if it has enough bandwidth to make corrections within the cycle of the switching noise, the % error is lower. You might try a switcher with an LC filter and linear stage after it, though this is getting larger, more expensive, and more lossy. It quickly gets to the point where you have taken as much space with the regulator board but runtime is same or possibly worse.
You've not defined the requirements. Min and max input and output voltage, required runtime vs amp current consumption, actual size limit, cost, etc. As oversimplifed as it might seem, I'll say that there is a reason why many people use 2 x 9V cells, it's not like they just forgot to think about what battery to use, unless they didn't bother to test their chosen amp /can combination to see how low the supply voltage could go before they could hear a difference, then picking the battery combination having that information. Certainly in some cases this seems true, but not applicable to all cases.
