Patrickhat2001
- May 13, 2003
Ever since I got my EMU 1212m a week or so ago I've been very pleased with the sound except something seemed wrong with the bass--the sound of the card was very detailed all throughout the frequency spectrum except for the bass which seem a little blurry in comparsion. I was a little dismayed by this since I originally thought it was the fault of the card but a few days ago I realized that it was the 24 bit padded to 32 bit decoding that was causing the problem. Upon switching the decoding back to 24 bit fixed-point (this is all in Foobar, by the way) the bass cleared up and is now as clear and detailed as the rest of the sound spectrum. Also switching back from regular 24 bit has gotten rid of some of the articficial brightness that I was noticing in the midrange, especially with string instruments.
I just thought I'd share this since I've read some other people complaining about the bass of the 1212m being blurry. Perhaps this has been the problem? I never noticed blurry bass using 24 bit padded to 32 bit with my other soundcards before but upon going back and doing some comparisions with between 24bit and 24bit padded on the Terratec EWX 2496 I noticed that, again, the clarity in the bass improved (although it was much more slight) when using just regular 24 bit. I've also found that I like the way 32 bit decoding sounds with the 1212m (something which never really seemed to sound good with my other soundcards--they just end up sounding overly bright). I know that technically the 1212 (alone with all other modern soundcards) is only rated for 24 bit decoding but for whatever reason 32 bit decoding does work with it (alone with all of the other soundcards as well). 32 bit decoding sounds much more detailed than 24 bit decoding although it can be too thin and really doesn't allow the sound to bloom as much as it should naturally. Still, if you want to know exactly what chords your favorite guitarists are playing I recommend giving 32 bit decoding a shot.
I guess the real point of this post is just don't follow the recommendations of others blindly; experiment and find what's right for you. For the record I've also given up on upsampling with Foobar since I found the sound more with upsampling disabled. To each their own I guess. Computer audio can be maddening sometimes since their are so many settings to play around with.
