Could you please repeat that in Greek so I have a chance to understand?
Thank you for your effort.
What about them curves?
Well, they look okay, not sure where they bias in the GOTL, but would want to operate them at a highish current to get the load line out of the large knee of the curves!
FYI, most people are using these as output tubes, preferably 3 per side.
Sounds like people like the results too. Better than 6BX7 would you say, @gibosi ? Well I have tried to chime in with technical explanations in Glenn's absence as best as I am able, so happy to help when it comes to interpreting datasheets and whatnot.
I found that the Melz 6N12S has an incisive (biting) quality with great clarity and instrument separation and with the right driver tube(s) they can sound excellent. -Did not experience the same with the 6BL/X7 tubes.Your efforts are much appreciated.
And I don't know as I would say the 6N12S is "better." To my mind it sounds like a Melz or Telefunken 6BX7, if they existed. And even so, I'm sure that some would still prefer RCA or Sylvania or what have you.![]()
That happen to me 4-5 years ago i had a 274B Sophia Princess that became very bright but was still working i to shut it off right away .Never check on it afterLast night, after using the Z63 tubes for around 12 hours, there was a pop and one of the tubes started to glow significantly brighter than before. I shut off the amp right away.
Does this very much increased brightness indicate that the tube is failing?
Is it dangerous to continue using it?
I immediately shut off the amp with that Z63 tube that suddenly made a popping sound and then turned very bright. The next time I turned on the amp it did not turn on - a fiery death...That happen to me 4-5 years ago i had a 274B Sophia Princess that became very bright but was still working i to shut it off right away .Never check on it after
I am testing an ST type tube with an anode cap in the 6J7 family. It sounds very good with one caveat - of the three different makes I have, all of them hum to a greater or lesser degree. It is a low level hum (similar to 50hz hum) that does not vary with the amp volume; other tubes in the same family are quiet.
By wrapping the tubes in aluminum foil AND grounding the foil to the amp chassis I can reduce the hum - some of the sets are still objectionably humming, and some less so, but the hum is there even though some of tubes are listenable.
I am sure that the hum comes from the tubes themselves. Does anybody have an idea of how to eliminate it?
The adapters are from Deyan and I am sure that the anode wires are well shielded. As I mentioned, other similar tubes do not make a humming noise with the same setup.Is the wire going to the anode cap shielded (with one end of the shield tied to ground)? That's helped in the past for me.
