@Xcalibur255 interesting and helpful info. on Hexfreds. From your description sounds like I may go with Hexfreds too, especially the sound having better bass control and speed, and resolution... but doesn't that change depending on how good of rectifier tubes you're comparing it with?Very easy to hear differences. I guess it depends on what you are focusing on. Both myself and a number of other members here feel the Hexfred sound is a little on the dark and mellow side in terms of tone, but how much of this is due to the diodes and how much due to the change in voltage drop is hard to say. The clear and measurable difference is that there is no voltage drop, where as with a tube rectifier there would be anywhere between 20 and 60 volts of loss which changes the operating points of the other tubes in the amp. This is the primary reason why rolling rectifiers can change the character of an amp. It's inducing a change in behavior from the other tubes. The Hexfreds aren't noticeably more or less dynamic than a tube rectifier to my ears, though they have substantially better bass speed and control which you might choose to interpret as a more dynamic sound if you wanted to. I also found them to offer superior resolution and low level detail over tube rectifiers. Unless you specifically want your amp to have a brighter sound the Hexfreds are kind of a slam dunk if you ask me.
The other main audible difference comes from the amount of diode switching noise. This is where I feel the Hexfred really earns its keep and is the reason why I don't use tube rectifiers in my amp anymore. The Hexfred is a more refined and grain free sound that has less hardness and glare than any rectifier I ever owned or heard, and I believe that is mostly due to the fact that there is less switching and hash noise from these diodes compared to a tube diode.
The main downside is you lose the gentle and slow start up that tube rectifiers naturally have, but Glenn has ways of dealing with this so it's not really a problem.
As for a difference between having Hexfred in a removable socket adapter or having it built into the amp, I really doubt there would be any difference substantial enough to be able to hear it. It's the same diodes either way. If you want to preserve your ability to roll in different options then the adapters are the safe route, but if you are confident you would like the Hexfred sound you can eliminate one or two tube sockets from the amp and free up space for the chassis to be smaller or for other things to be up there depending on what you have in mind.
For the next questions, excuse me for sounding like a noob but I'm coming from the simple 4-tube OTL Feliks Audio amp with drivers/powers of the same socket type.
- Does the Hexfred option even apply to a new GEL3N amp, or is it only for OTL amps?
- Can someone PLEASE post a photo of the Hexfred? For the life of me I can't decipher which photo on Google Images resembles one. (I have no idea what it looks like)
- Is there such a thing as Hexfred rolling, such as op-amp rolling? If so, what is the terminology of the removable component?
- Which is more recommended for low-z cans, either the Hexfred or tube rectifiers, and 1 or 2 tubes?
