JazzVinyl
- Jan 7, 2010
Here is a long article about the 6JD5 tube, but it is too technical for me. However, it appears to me that this could be a good audio tube.Well, I know only a little about the 6JD5, but if I understand correctly, this power beam triode can provide up to 35 watts, transformer-coupled, and virtually any small double triode, for example, a 6SN7 can drive it. So instead of using very expensive and rare pairs of 300B, 2A3 or 45, a pair of these are much cheaper, and likely will sound just as good, if not better.
https://www.radiomuseum.org/tubes/tube_6jd5.html
I bought these. =) The guy actually took a VERY reasonable best offer price. Just you know...prepping for my OTL!!!!
In the meantime:
Been loving my time with the Gel3n. After sending Glenn the auteur he really brought out the most from it with the Gel3n. The impact, space and timbre is just a ton of fun and so life-like. As you can sorta see in the pic, I am running an old Brimar 5U4G that was made by GEC with the rounded base. I also have a skinny Mullard GZ37 that sounds wonderful per Glenn's suggestion! I have used a few rectifier's so far but to be honest they all sound so good in the amp that I'm just going to let this one sit for a bit before I really try to pick apart the differences. I'll probably go to the metal base GZ34 soon.
Also I am running it from a vintage Sonic Frontiers SFD-2 MK II which is just awesome. The combo is incredibly musical and lush without losing any air or space. I have a bit of a vintage DAC problem as well as the tubes too. My favorites are the EAD dac's and Sonic Frontiers SFD stuff.
I'll try to chime in more as I get more time with it!
How does it compare to ampsandsound stuff like Pendant?
ZMF headphones hand-crafts wood headphones in Chicago, USA with special attention to exceptional sound and craftsmanship.
Stay updated on ZMFheadphones at their sponsor profile on Head-Fi.
They're both great but very very different. The Gel3n is more alike the Mogwai SE than Pendant - I have only directly compared those two as the Pendant is a bit different in design (they all are really). When you're looking at the absolute best of the best tube amps there's no right answer. The Gel3n and Mogwai SE are two of the top tube amps I've ever heard, it's going to come down to personal preference.
A big part of the answer also comes down to how much tube rolling you want to do.
What is absolutely true is that Glenn and Justin (ampsandsound) are in their prime and we are witnessing master's at work!
How much does the Gel3N cost?
the 3 Lundahl transformers cost me $1000 by themselves.
There is some serious copper in those transformers!!!! By far the largest/heaviest on any amp that I have.
Trudging down tube rolling lane. Assembling the next platoon of 6BL7 with military precision.
Today is Sylvania flat parallel plate day - the recruits were born between 1951 and 1953. Now have to check if there are any duds...
1) Amp off, speakers off, no headphones, driver in place. Insert two tubes.
2) Turn on amp.
3) Wait a couple of minutes.
4) Plug in sacrificial headphones. (Koss Porta Pro with a lifetime warranty, just in case.)
5) Put on headphones and turn up the volume, listening for noise and any untoward pops etc.
6) Listening to music via headphones
7) Turn on speakers
Surprised at the volume and sound with just a driver and two 6BL7 tubes. Sounds fine.
8) Repeat procedure with an additional two tubes.
9) Everything OK.
10) Repeat procedure with another two tubes.
Putting on the analytical hat and listening to the system. I think that Sylvania tubes in general have a wide sound stage; it is certainly evident here.
First impression: Very vivid and engaging presentation. Sounds better to me than the GE and Tung Sol 6BL7 combinations that I tried. The GE and TS sounded similar but with more bass extension from the TS.
Tried several drivers - so far the best one with the 6BL7 to my ears is the RCA 1633.
I also have Sylvania 6BL7 with X plates but I am reluctant to change anything now since it sounds so nice.
Thanks - good to hear. And you saved me from rolling the X-plate Syl 6BL7 lol.....The Sylvania flat plate are the best sounding of the 6BL7s
I use one for the output cathode follower in my #26 tube preamp the only 6BL7 I will use.
