1964 Ears Adel IEMs
- Thread starter ads1107
- Tags
- asius-technologies-adel-g1-auto-modules 1964-audio-u8 64-audio-1964-ears 64-audio-a10 asius-technologies 64-audio-u12-universal-in-ear-monitor asius-technologies-adel-manual-adjustable-modules-mam asius-technologies-adel-b1-auto-modules asius-technologies-adel-s1-auto-modules 64-audio-1964-ears-adel-u6 1964-ears-adel-a12-custom-iem
torpedorag
- Apr 3, 2014
- Messages
- 245
- Reaction score
- 38
the medium spiral dots are smaller.That was the impression that I've read before, always heard that they were treble killers, and I'm just looking for a bit more air and treble emphasis. Glad to hear that JVC spiral dots fit our IEMs. Will be my next purchase.I find comply kill the treble. If you are using foam, try using silicone. I love JVC Spiral Dots with 64 stuff. The bore is big enough to completely get out of the way of the nozzle and let the iem do its thing.
If the medium Comply's fit me well, would the medium spiral dot be similar in size?
Thanks!
Sent from my LG-H815 using Tapatalk
PinkyPowers
Reviewer: The Headphone List
I tried the medium spiral dots on my u6 and I noticed that the length is not enough for the entire length of the nozzle. The part of the nozzle sticking out irritates my ear. Now waiting for my spinfits to arrive
From the JHA Angie thread:
If your tips are too short for the nozzle, spacers are the way to go.
I make them myself. Just cut a very small piece off the stem of one of your silicon tips. Preferably cheap ones you'll never use. That's what I have now for the 64Audio U12. The nozzle pokes out the top of my Medium Spiral Dots, but a super thin spacer makes it perfect.
After a few weeks of listening to my U10, I'm noticing that there is a bit of a lack of air in the upper frequencies, and there is a particular high frequency range that is a bit soft for my tastes. Everything else sounds awesome.
Would going to different tips than the stock Comply's boost the treble a bit?
Also try spinfit if you can, I found it to work very well with my U12
torpedorag
- Apr 3, 2014
- Messages
- 245
- Reaction score
- 38
silly me how can i have missed that? I`ll try it later at home. Thanks!I tried the medium spiral dots on my u6 and I noticed that the length is not enough for the entire length of the nozzle. The part of the nozzle sticking out irritates my ear. Now waiting for my spinfits to arrive
tim0chan
- Sep 28, 2016
- Messages
- 1,400
- Reaction score
- 732
The spiral dots would fit but they need a spacer. U can pm me for a tutorial. I find that the blue stem eartips from noble work very well to and do not need a spacer.That was the impression that I've read before, always heard that they were treble killers, and I'm just looking for a bit more air and treble emphasis. Glad to hear that JVC spiral dots fit our IEMs. Will be my next purchase.
Thanks!
flowza
- Oct 18, 2013
- Messages
- 65
- Reaction score
- 13
Do you guys recommend switching to the apex m20 module? I just got the ADEL u8 a few weeks ago and they sound great, but I looked into it and I'm seriously considering buying it.
flowza
- Oct 18, 2013
- Messages
- 65
- Reaction score
- 13
Also dyu guys think I should buy a new cable? I'm thinking of buying one and I have no idea where to look, any recommendations would be appreciated (<$150 please)Do you guys recommend switching to the apex m20 module? I just got the ADEL u8 a few weeks ago and they sound great, but I looked into it and I'm seriously considering buying it.
torpedorag
- Apr 3, 2014
- Messages
- 245
- Reaction score
- 38
What is your reason for changing the cable? is it for sound? I think trying different modules, tips and/or using impedance adapter would change/improve the sound more than a cable upgrade. If for ergonomic purposes, I would suggest linum cable. I use the Linum music mmcx with my Fidue A83 and it disappears. Plus, there is a slight improvement in sound.Also dyu guys think I should buy a new cable? I'm thinking of buying one and I have no idea where to look, any recommendations would be appreciated (<$150 please)
I am considering norne therium for my U6 but first I would buy the B1 module and an impedance adapter and see if I like the sound already.
Dithyrambes
- Dec 8, 2014
- Messages
- 813
- Reaction score
- 283
Anyone looking to get a A6 CIEM, have a really good deal. Looking to sell these fast and priced accordingly.
http://www.head-fi.org/t/787339/1964-v6s-ciems-upgrade-ready-final-price-drop
Thanks!
Thanks!
tim0chan
- Sep 28, 2016
- Messages
- 1,400
- Reaction score
- 732
U should look into null audio for thatAlso dyu guys think I should buy a new cable? I'm thinking of buying one and I have no idea where to look, any recommendations would be appreciated (<$150 please)
maniac2003
- Jun 20, 2009
- Messages
- 656
- Reaction score
- 179
Do you like the S1 module?
I also bought the B1 for my U8. Bass punch is less but it opens up the soundstage a bit. For the moment I'm back to the S1 module for the slam.
Cable: would the Linum BaX cable be something you'd fancy?
I like their cables a lot. Sometimes a bit springy because they are almost weigtless
It doesn't alter the sound much, if any, from what I hear. I changed from stock because I was already scraping off some plastic from the IEM-side connector. The used plastics are to soft in my opinion.
Don't waste your money on cable unless you want to have a DAP or DAC/AMP that have a balanced connection, then you can buy a cable to use with that source. You can spend less on a module that will really chance the sound not a stupid cable.Also dyu guys think I should buy a new cable? I'm thinking of buying one and I have no idea where to look, any recommendations would be appreciated (<$150 please)
tim0chan
- Sep 28, 2016
- Messages
- 1,400
- Reaction score
- 732
I do agree that the modules make a larger difference but I do believe that a cable can also make a difference, however small. I personally use the null audio vitesse copper,and have noticed an improvement in resolution and clarity, not to mention bass and treble extension too.Don't waste your money on cable unless you want to have a DAP or DAC/AMP that have a balanced connection, then you can buy a cable to use with that source. You can spend less on a module that will really chance the sound not a stupid cable.
Audio Addict
- Aug 5, 2001
- Messages
- 4,323
- Reaction score
- 503
How do you purchase those? Noble's website just has a massive $30 mixed collection with $10 shipping.
