warrior1975
- Dec 5, 2013
Maybe to save some money?
WHy don't you buy from 1964 Audio website? You don't have to wait, just go there and click on Order, done.
No problem. Yes, that is my concern as well and the reason I am unable to decide between the A10 and A12. It'll be nice if 64Audio offered the MAM as a default option.
@Wilderbeast
, I see that you owned an IE80 in the past. If you could speak from your memory, would you say that your A12(with Auto modules) is bassier than the IE80?
Thanks for your help.
I can't answer that properly, I'm afraid - I could never find tips that gave a good enough seal on the IE80 - the included tips were useless!
My A12s are easily the bassist IEMs I've owned. With the Auto Module I think the A10 would have better suited my needs. I'm certain my A12s will be 'put right' with the MAM though, going by what others have said.
I'm in the same boat as you. I have the A12's correctly matched to a neutral source with .075 output impedance(chord mojo) so I should be getting the best treble I can get from a source based on the impedance matching.
I'm looking at the MAM to level out the A12's first and then if that doesn't get me where I want, one of those fancy audiophile silver twag cables that may brighten the sound a bit.
I think the MAM will probably do it, hope anyway.
I'm not hating on my A12's by the way, I absolutely love them. Just wish I could get the sound a smidge brighter and get a little more treble out of them and I'd never need another ciem/iem ever. I understand why Vitaly tuned them with more bass, because if you don't overdo the bass a bit you won't notice a difference with the manual modules.
The cable will absolutely help.
Btw, I have been using a Calyx M with my A12 and even though the silver cable helped, the treble wasn't enough and the bass overwhelmed. It got better when I switched the impedance setting. The Calyx is a very warm DAP.
However I just purchased a Hifiman 901 from a member and what a difference. A much more forward sound and now got that treble that I was looking for. It also made an already wide soundstage, even wider.
You mirror my thoughts exactly.
It's a little frustrating because I understand the A12's potential - If I eq down the bass (I dislike using eq at all) I get a sense of how good they are.
I've also tried listening with my Mojo; it's a slightly warm source and the result isn't great. However, when I use my Hugo, which is neutral (or slightly bright) it sounds better. It's almost, almost a wonderful sound.
Bring on the MAM!
I like the idea of the hifiman and it has legendary sound, but I need my streaming and for that I need a phone. =/ Don't really want to carry around another device right now, my streaming consists of bandcamp and youtube.
Pardon my ignorance, but if the Calyx M is "very warm" shouldn't it be produce an even more veiled sound than the mojo? Mojo is pretty much perfectly neutral with a slight rolloff in treble to make it easily listenable for hours on end. I appreciate that my A12's have never demonstrated ANY sibilance even with the most grating recordings I have, but a little more treble would be welcome.
If only the 901 was a sleek modern touchscreen style device that could access apps, something like the ZX2! =P
I play bass in the worship band and had the opportunity to demo the U4 and a universal V6-S with the supplied demo tips this weekend. I found the V6-S to have better mids and highs than the U4, but the bass did not stand out enough for me to really hear myself. The bass on the U4 was better, but it tended to overwhelm the rest of the sound. I ended up using the U4 for most of our services, but if I had my pick, I would have liked the U4 with a little less bass or the V6-S with a little more bass. All of this was through a small, inexpensive headphone amp with a mono mix (all that is available from the board). No EQ.
The demo information said that "Generally the demos have a little more highs and a little less bass compared to the customs." As I want to go the custom and not universal route, this would tend to make me believe that the A4 would have even more bass than the U4 ... not in the direction I really want to go. Am I wrong in my thought process here?
Thanks!
