The best IEM is the JH Audio Layla II ($2799). Go with 1964 Audio A12, it prevent you from getting your Ears damaged. Besides 1964 Audio IEMs and JH Audio, there are no other good IEMs out there atm.
These 2 companies are the Top
I sold the Mojo/AK320 combo. I didn't like the SQ. Detailed but too thin sounding. Interestingly enough, the guy I sold it to also turned around and sold it for same reason.
I didn't have the A12's long at that point.
I have Whiplash TWag gold/silver and also their Silver Litz cable. I have to go back and compare both now that I changed the impedance settings on the Calyx M.
I own or have owned the LAB 1, Ref.1, K3003, Jupiter, Parterre, K10U. (Not sure if these would be considered "best in the world") Of these, I prefer my U12 due to its expansive soundstage, precise imaging and sense of realism.
These guys with the Adel, do they do that suction thing with silicon tips? Just trying out my new u8s, and am feeling like I have a good seal (Spiral dots) but more like how a comply seals without the super suction thing. A little tiny bit of suction, but not as much as I normally get with my iems.
I had to stop using the spinfits. I was told they go in deep. The problem was they stayed in my ear a few times. Once I pushed it in deeper and had to get tweezers and to pull them out. However, I modded my W4R with the spinfits and they work great on those. I ended up using the star tips from Westone on my U12. No chance of those coming off.
Just a quick update on my cable issue - and testament to the service of 1964Ears. I heard from Alex earlier today. They've already issued an RMA order, arranged a replacement cable, and will be sending it out to NZ (along with my case and accessories - which initially went missing).
I'm going to send the original able back to them so they can talk to their manufacturer. Apart from the broken side piece, I have no issues with the cable, and am more than happy with a replacement.
And once again this shows (to me anyway) what a great company 1964Ears are to deal with. No fuss, no debates - just acknowledgement of the problem, and willingness to work towards the best solution possible.
I have no doubt at all that I'll continue buying their products for years to come.
U6 review should be posted sometime in the coming weekend.
I stayed out of the posts talking about ******** that followed your post last night and waited for 64 to do what they did for me which was their job. They resolved my issue. Glad they showed it to be a pattern...a good pattern which is not as gimmie in this business.
I think the modules/ADEL technology contribute to the loss of suction/pressure. I briefly tested out my U12 without any modules and there was zero suction, and it actually felt weird. When I used my fingers to block the vents there was more suction than with the auto modules, so I'm guessing with the MAM fully closed there would also be slightly more suction.
So with the ADEL module, there is less pressure when u put the U12 in your ears? And when u take out the ADEL module, u feel the pressure again just like any other IEM? is that what u said?
