12v T-amp power supply
Sep 8, 2005 at 3:38 PM Thread Starter Post #1 of 1
DJEverytime
Hi, i've found a 12v battery: COLEMAN PMB8110-RS POWERMATE PORTABLE POWER SOURCE!
http://cgi.ebay.ca/COLEMAN-PMB8110-R...QQcmdZViewItem
problem it it's bit heavy, i also found a, light weight, 9.6 v portable battery that works, but i havn't tested it for more than an hour.
My question is: will the coleman 12v battery work with the t-amp and how well?
and; will the 12v battery makes that much different to sound versus the 9.6v or just 8x aa's?
