ivo001
I have ordered these on 11.11This is the case I like using with the ZS5 and ZS6. Especially with the memory wires, they are so bulky that they work in this case as opposed to all of my other ones. With this case, I can lay them in without disturbing the memory wires (ie mangling them all of our shape). That way, they are ready to go for next time.
The foam can also be used for mods.
https://www.gearbest.com/headphone-accessories/pp_605419.html
https://www.aliexpress.com/item/201...32703512553.html?spm=a2g0s.9042311.0.0.HulOpH
Do you think it is too small to fit a ZS5 in due to the memory wiring?
I've read it is not adviced to detach cables after every use. Was thinking of storing the cables in the top section before, but guess i'll keep my stock cable there, and keep the upgrade cable attached.
