Recently got a new computer with Windows 10, had a laptop with W7 for 5 years and I owned this DAC/Amp for over 6 months now. I'm very happy with till just now as it doesn't look like it "gets along" with W10 very well. It basically stops playing after about a minute or so and I have to restart it, or restart the computer or both. Tried it with 2 different media players and and all the available streaming methods.[Direct, WASAPI, Asio.] It worked great with W7 with the TEAC supplied driver, and it is also flawless with my LG v20 Android phone. I did try to uninstall the driver and reinstall with no difference.Went through all the settings I could think of.
Any ideas?
Do you have the Win 10 anniversary update? I had some issues when the anniversary update was installed, did a revert to previous version, un-installed the USB driver for the UD-301, re-did the anniversary update, and then re-installed the USB driver. Seems to work great now, but have since installed a Xonar DG sound card and use the optical port and in-installed the USB driver. On another system the anniversary update crashes all the time so just reverted to previous version and will pray that the next version update fixes the issue.
