Shanling M2s Hi-Res DAP with AK4490 + MUSE8920, Bluetooth, & USB Out
Jun 26, 2017 at 7:09 PM Post #1,051 of 2,460
:smile_phones:
Audirvana Plus, OS X 10.11.6, in USB DAC convertor mode, confirmed!
No diver required, but application should have exclusive access enabled.
Decibel works too with the following settings:
When Core Audio changes sample rate M2s follows (with current sampling rate and bit depth displayed on the screen, very nice feature!), but only up to 24bit/96kHz, so 192kHz files are downsampled to 96kHz when playing via Core Audio, but play at 192kHz via applications that support exclusive access (thus bypassing Core Audio altogether).
Jun 26, 2017 at 11:13 PM Post #1,052 of 2,460
@Joe Bloggs - I was using the HiBy Link app with my M2s on Friday, and found that the app won't rotate to Landscape mode on a tablet.
I used 3C Toolbox Pro, to enable rotation, and HiBy Link crashes.
It's true, the HiByLink-enabled HiBy beta does not yet support landscape. Neither would the official version coming out shortly :deadhorse: Sorry about that, we'll add it as soon as possible.
Jun 26, 2017 at 11:26 PM Post #1,053 of 2,460
I've got some friends who make custom leather cases, pouches (and even leather armor costumes) - so I'm going to get some custom cases made, with a protective screen cover flap, for my Shanling M1 & M2s, and Cayin N3. They'll also have D-Rings, so they can be attached and hang from badge lanyards, or belts.
Unfortunately, I don't know anyone with that kind of leather skills. :frowning2:
Jun 26, 2017 at 11:31 PM Post #1,055 of 2,460
I just tried with a M1 and couldn't get it to work with any of my Android phones or tablet. Works with my computer and the provided drivers.
Try installing HiByMusic on your phone :wink:
Jun 27, 2017 at 1:31 AM Post #1,056 of 2,460
I appreciate the quick response :wink:
Humm.. I'm using the Beta with HiBy Link, it replaced HiByMusic upon install. Can I still install HiByMusic again? Or am I limited to one or the other for now?
I wish I could run both apps separately on my phone and choose which to use, until the beta is finished and rolled into one.
I guess I could Just run standard HiByMusic on one of other phones and give it a go, for now.
Thanks.
Jun 27, 2017 at 3:33 AM Post #1,058 of 2,460
Thanks.
In that case... we're updating our HiByMusic officially from 2.34 to 3.0.0 in a few days, you could wait for a bit. And yes, there were some DAC connection problems with the 3.0.0 beta posted on the Play Store :bow: (apart from enabling connection on Android 7.x systems for the first time)
Jun 27, 2017 at 3:38 AM Post #1,059 of 2,460
Great, I look forward to the official 3.0.0 update! :ok_hand:
Jun 27, 2017 at 12:33 PM Post #1,063 of 2,460
@Shanling is it possible to add a battery percentage or a option to choose from battery percentage or the battery icon ? Or have both :ksc75smile:
I would love to have percentage as battery, so backing you up in this :wink:
let's see if the 30:00 bug will be fixed....
30:00 bug? Please what you mean?
Hi Shanling, I think this should be the best present for all of us!! two microsd slots on marvellous M2S.......
Why only two? What about 4?? :D
In other news, MusicDay's M2s arrived to us, we were able to fix it with cloner software, now running smoothly again :) So don't worry guys, if your M2s stops working, there is always way.
Also, our units got fancy sticker today :D
DDUlhVoXYAAahU_.jpg:large
Jun 27, 2017 at 1:56 PM Post #1,065 of 2,460
