geoffsdad
- May 30, 2015
Which side is postive and negative on the 2 pin?
As long as you have the red and blue dots facing upwards they are plugged in correctly.
Any news on super balanced?
Does that really matter? I plug them in randomly upward or downward, but I make sure two sides both have same position. Works no problem.As long as you have the red and blue dots facing upwards they are plugged in correctly.
Hi. We would love to be there, yet we cannot make it this time. Sorry.@Linum - will your company be attending CanJam London next month? It was nice being able to listen to the Super BaX there in 2015, and it would be great to be able to listen to anything you've got to exhibit or show as a prototype at this upcoming CanJam.
Thanks in advance!
Thanks for the quick response, appreciate it!Hi. We would love to be there, yet we cannot make it this time. Sorry.
Hi guys.
A new improved Linum generation - Linum G2 - was successfully launched in August.
We know some of you have had your share of challenges with the first generation. Thus, we want to let you know, we have received no claims on the new generation. Though difficult to avoid entirely, we expect the claim rate on G2 to stay very low.
Implementing the learnings from the first generation, the G2 is improved on several parameters. With an angled jack plug and strain relief, the cables are tested considerably more durable. The cable is redesigned, yet sound performance and the comfort of the cable remain the same. However, with the SuperBaX a new dimension is also added - with only 0.75 ohm this is the closest you come to a pure sound experience… and the SuperBaX was born only because you guys asked for it.
In case you wish to update your audio gear with a new Linum G2 don’t miss our Black Friday sales. Check it out. This Friday only!
