paecificjr
- Mar 24, 2016
I found a pair of Koss K-6 at an antiques store and impulse bought them. Now I'm trying to refurbish them. There is a crackle when the cable is moved and they only work when the cable is in one particular position, so I will be either redoing the connections or the entire wire, but I digress.
What I need are some earpads and a headband. The original ones from the 70's are not pleasant to wear. What are my options?
