depon
- Jul 29, 2016
Hi,
I want to make a splitter cable/adapter. The stereo source signal is going to split into two cables. The two cables will go through one rotating potentiometer each . Each will then end into its own 4pole socket/jack (R+),(L+),(R-),(L_-). Then one could attach headphones directly or separate (even balanced) headphone amps with headphones.
Will there be any difference in sound quality between the following cases?
If there is a possible preference in sound quality between the following cases, would someone please tell me in what order?
Does the cable length play any additional role in differentiating these cases any further? In other words, will any possible differences amplify in case of a short 0.5m cable or a long 5-10m one?
The difference between those cases have to do with the point where the cable splits... directly at the source point or at the pot-end point.
It would be really helpful for me to know in order to know what kind of cable to purchase since it will have to be a relatively thin one. Specifically, I would know whether I should choose a 4-6 or 8-conductor cable and the answer would save me experimentation time and money + teach me a thing or two.
CASE_1
(R+)-===========(pot1,pot2)
(L+)-===========(pot1,pot2)
(R-)-===========(pot1,pot2)
(L_)-===========(pot1,pot2)
CASE_2
(R-)------------------=(pot1,pot2)
(L_)------------------=(pot1,pot2)
CASE_3
(R+)-----------------=(pot1,pot2)
(L+)-----------------=(pot1,pot2)
(R-)-----------------=(pot1,pot2)
(L_)-----------------=(pot1,pot2)
Thanks in advance
CASE_1
CASE_2
CASE_3
Thanks in advance
