[Problem] AMB M3, noise and capacitor smoking
Oct 18, 2010 at 9:34 AM Thread Starter Post #1 of 17
charlo89
Hello,
My m3 worked perfectly a few days ago. But since one week I hear noise. Impossible to remove with a ground locker. But when I isolate the potentiometer chassis the noise disappears. But it is impossible in my setup to isolate it. More ever recently when I turn on the M3 the ground louker smokes at the capacitor.
I use this method:
I think that a component is dead on the ground channel, but I have no idea of the culprit.
Thank you for helping me.
Best regards Charles
Oct 18, 2010 at 12:10 PM Post #4 of 17
Oct 18, 2010 at 2:37 PM Post #9 of 17
EEK! the PowerSupply should be isolated from the chassis.
Ground on the M3 board is 1/2(power supply)V above V- assuming you have a 24V supply, you tied 12V to ground through a 10ohm resistor... this burns off ~14.5W. If your power supply is higher than 24V you are burning off more power.
Oct 18, 2010 at 3:28 PM Post #13 of 17
this is worrying, I wonder what happened to the S11......
Oct 18, 2010 at 4:05 PM Post #14 of 17
my transformer 220v 30va destroyed 2 S11, I prefer to forget the S11 and buy a PSU Vellman
But the problem is that my PSU is isolated from the chassis. V- and V+ aren't connected to the chassis.
