adalberto vela
I have a chance to obtain a Sony PHA-2A as a thrown in through a trade and was wondering if this portable amp w/ 4.4mm balanced will better the sound from my DP-X1..? If it will improve it any, would like to have it...
5h battery, bulky, heavy and only ES9018K2M DAC, how that suppose to be better than x1a?I have a chance to obtain a Sony PHA-2A as a thrown in through a trade and was wondering if this portable amp w/ 4.4mm balanced will better the sound from my DP-X1..? If it will improve it any, would like to have it...
No, the difference is very little.Thanks for the message, but I do have the X1 not X1A..Is there a huge difference in sound between the 2..?
I get around 12 hours of play and 2 weeks on standby, thats pretty good. You should try the X5iii, thats the worst so far for me. My HM901 has bad battery life to but i knew that going in.I really like my DP-X1, but that battery is the worst battery life I've ever experienced on any electrical device, EVER!! And it's not close!!
I ran into this issue before I don't think it is glue try to fix it by moving and bending the inside connector toward the center with a thin needle.Actually I put 2.5 mm port back - applied some epoxy adhesive. It is firm connected now.
The only issue is that I lose a signal in some positions of the 2.5 mm jack while rotating it. Could be a glue on the contact somewhere.
yes, could be. The problem is that everything is so tiny, will try one more time..I ran into this issue before I don't think it is glue try to fix it by moving and bending the inside connector toward the center with a thin needle.
Hey all, anyone know if I downgrade and use the LG V20 instead of this lovely Onkyo Dp-X1 would I miss the Onkyo ? Is the V20 that much worse sound wise ?
Are you connecting at 2.5G or 5G? Streaming has issues at 2.5G, but is crystal clear at 5G.it seems like it was spotify that was the problem because when playing transferred flac files, they play flawlessly.
I have both and I could live without the LG V20 but still love having the DP-X1. Ive had the DP-X1 longer than any other player Ive had in all the years and many DAPs since I started this expensive hobby.
