ScareDe2
- Aug 30, 2016
Hi,
My problem with my sound quality is inconsistency. It is playing faster or slower and there is some distortion affecting the transparency, dynamics and rhythm. The sound changes all the time.
Recently I have opened my PC case and realised some parts, likely capacitors/inducors, are producing high pitched noises. But they are not leaking and everything looks clean on the motherboard. I have applied some nails polishing on some part and it has help reduce the noises. I dont really care for this 7 years old mobo I have planned to replace it eventually.
My question is, if I apply nails polishing or glue all over the parts I think are noisy, that will indeed reduce the noise, but I do not think it will fix the underlying problem with those noisy parts. Is there anything else I can do? Thanks for any help.
