Dartin Bout
- Jul 8, 2016
I've had my LG-H990 since it was launched in South Africa in late November 2016, and have used it almost exclusively as my go-to DAP since then. Herewith my impressions.
It is without any question the best sounding smartphone by a huge margin when used correctly i.e. with high quality, high impedance Dynamic headphones plugged directly into the headphone jack. Nothing else in my experience even comes close on any level.
I have used primarily Beyerdynamic DT770 Pro 250 ohm and AKG K171 MkII cans since these give me the sound quality I'm looking for.
This phone will compensate for whatever is plugged into it over 50 ohms. It is simply phenomenal. The Beyers are 250 ohm, the AKGs 55 ohm. Although the AKGs are lower impedance they are a bit less sensitive than the German monoliths.
Here's the thing: the V20 outputs EQUALLY loud with each! It somehow compensates for whatever it needs to drive. I have no problems with gain, and I like to listen reasonably loud to mainly Rock and Metal. I have used 80 ohm DT770s and they do not go noticeably louder than the 250 ohm version, which sound far better to me. I have listened to a number of quality headphones through the V20 and it drives everything with sufficient gain up to HD600/650s. It does NOT however like Planars of any description...
It does struggle with some low dynamic range material (some 24 bit 96KHz vinyl rips for eg.) I can live with it since the LG sounds great even at maximum output - I can hear no distortion of any kind when pushing 75.
SQ is up there with the very best DAPs IMHO. Treble is accurately rendered, the soundstage is wide open. Definitely on the bright side, this is NOT a warm sounding device. That said, at no stage on high quality source material did I ever feel that I was listening to something that wasn't part of the original recording. What goes in comes out of your cans with very little added. Poor recordings are hell to listen to however, as this phone is very unforgiving in it's accuracy. The Sabre DAC is known to be thus.
Bass is very well presented: deep and highly accurate with no muddiness whatsoever. Amongst the very best I've heard at ANY price point, and that's saying something. Listening to Rush's "Closer to the Heart" off "Different Stages Live" in 16bit FLAC and Geddy Lee's bass is the stuff of legend!
What really amazes me though is what it does to high quality 320kbps recordings. I don't fully understand the manner in which it supposedly upscales this material, but whatever it does it makes these sound very impressive indeed, to the extent that on many recordings I don't feel the need to have FLAC copies at all! This goes against everything I assumed when I first got the phone and listened to Hi Res FLAC exclusively. Another Head Fier described it as "organic"- I prefer "supernatural"...!
So yes, you could say I rather like this device - in fact I am still slightly in awe of it and need to constantly remind myself that it's actually a Smartphone and not primarily an audio player.
The convenience is just astounding, and my portable amps/DACs have now become desktop items...I can give the V20 no greater compliment than that.
I concur wholeheartedly. I might suggest you record live music at 24\192, with the phone and get some good garters. It will blow your socks off. Live, highly amplified rock\metal, will take some finagling with the settings but jazz, classical or any acoustic will rival the quality music directly from the mixing board with the no effort from almost from any place in the venue.
