Paul - iBasso
Sponsor: iBasso
Hi Paul,
did you notice my post ?
yours
Yes. I gave the information to my software team. There are a few things that can be changed but some can not.
* USB Dac mode doesn't work: the sound is completely distorted when i try to play music from my computer.
----We don't have this problem and have tested it extensively.
* When i play music on a Bluetooth device, only 44khz files are working. when i try to play a file with a higher rate the app is stopping playback or is going forward a few seconds in the song randomly
----It is bluetooth, which only can take 44kHz streaming. Our player is bit for bit.
Is it possible to disable Digital filter ? if i'm not wrong we can only choose between the 7 filters but we can't disable them completely
----This is impossible. If no filter is used then there would be a great deal of generated noise heard.
* locked screen widget should be bigger and have music control buttons
---We have side physical buttons.
* setting lock screen to none doesn't work
---This is being worked on and will be corrected in an upcoming FW release.
To answer a few of the questions.
Stay updated on iBasso at their sponsor profile on Head-Fi.
