Mr Trev
Yup. Bought my 400i when they were on sale round x-mas for $350CAD. Pretty good deal at that price IMO
Yes, but I wouldn't use the stock cable, might be easier to just build a whole new cable since the stock one is not great due to the 90 3.5mm jack and the covering is a little microphonic to me.Sorry Guys. just quickly (Again)
if handed over to somebody whose handy with soldering, can the stock cable be re-terminated with a balanced connector? assuming V2 with the 2.5mm plugs
I didnt compare the stock pads vs the brainwavs leather face to face but i did some kind of front bassreflex mod to the brainwavz, to my taste the sound muddy because of de leather seal. Now the drums sound like its must sound. Amazing.They arrived. It wasnt easy to mount the ring but did it.
I have to say that i have not a lot of experience and i dont know what is a good sounding pair of headphones.
Definitly it sound diferent. I have to do more A/B comparations. They sound muddy coz the seal but more balanced, maybe.
The HD400i would be a little more comfortable since the opening is a bit deeper but like the HD650 the out of the box clamping force can be a bit much, I did bend mine so that the ear pads are not smashed together when on a stand.Just a quick one, since i'm deciding between 400i and HD650
I have rather large ears. How "deep" are the earcups compared to a beyer 770 or the HD650? I can wear the DT770 for some hours, but start to feel it pushing on my left ear after 2-3 hours. I haven't had much time with the 650 yet, but they felt a little better in that regard. Since the 400i would be the cheaper option, i'd like to make sure they are 1. comfortable and 2. they are not to analytical/heavy on the high mids.
Concerning number 2: On a scale from HD650 to K701 in terms of Analytical/Warmth, where would you put the 400i?
Thanks for the input.The HD400i would be a little more comfortable since the opening is a bit deeper but like the HD650 the out of the box clamping force can be a bit much, I did bend mine so that the ear pads are not smashed together when on a stand.
The HE400i is more on the analytical side to me, it doesn't have the smooth mids of the HD650 but is better extended in the lows and highs. I would put the HE400i right in the middle of the HD650 and K701
