r3dhotlava
- Feb 4, 2017
Hello all!
I'm seriously considering getting the STAX SRS-3100 system and I need help confirming (or suggesting) how to get audio from my PC to a DAC to the STAX amp, the SRM-252S.
(I'm copying and pasting the following from a review asking the same) What kind of DAC and cable could one use to get audio from the PC to the DAC to the amp? I have a optical audio coming out of my motherboard & I was thinking of either using Audioquest Beetle DAC because it has an optical input, or the Audioquest Red or Black Dragonfly, to 3.5mm out to dual RCA into the SRM-252S. Does that sound like a correct solution? Also, if you were to suggest the Red or Black, which on would you suggest?
Or any other DAC and cable suggestion. I just want to make sure I'm sure with the connections with the cables from A to B to C, THANKS!
