markk02474
- Feb 19, 2008
I bought my X20u ES9028PRO from topssale. They claim to test units before shipping. It was already set for 115v and included a 3' North American power cord. Still breaking in.
And another irk I had... even though I was able to send 4DSD DoP from JRiver to the X20, I wasn't able to convince Gustard dac to accept upsample DSD in native format. Even with asio codec selected, any DSD (no matter whether 8xDSD or 1xDSD) ended in error. Maybe I am not nderstanding it correctly, but I believe the USB should be able to accept at least 4xDSD in native no prob... If anyone could explain to me, I'd be most obliged.
This looks like a driver problem if you are using JRiver in Widows
Correct me if I'm wrong, but I don't think XMOS will accept native DSD no matter what you do? That means you're stuck with DSD-128 over DoP.
This seems to be a software/driver related thing.
With Daphile, I can upsample my CDs to DSD-128 native by the USB interface of X20 which is based on XMOS. A couple of friends here reported here that they can upsample to DSD-256 native. However, with foobar2000 or jriver in Windows 10, I can only upsample my CDs to DSD-128 by DOP.
I cannot for the life of me figure out how to upsample PCM to DSD in Foobar2000 with the X20U. Can someone please enlighten me? I have the SACD/ASIO components installed but I think it works only for actual DSD files, which I don't currently have. I really just want to try upsampling PCM to DSD..
Many thanks, indeed I am using JRiver under windows. I installed the cmos driver from supplied usb disk. Any tip how to make it working?
Man, something's not right, I took a look at the X20 thread. The CPLD is EPM570T100, the newer X20 Pro has changed to EPM240T100. Obviously EPM570 is more powerful. I guess they did this to reduce the cost. That's a pity.
BTW, yesterday my Fred diode order came in to replace the 8 on the DAC/buffer board and they make a huge improvement. My soundstage grew in every dimension. Its a mystery why Gustard put standard M4 SMT diodes on that board when they used low noise SS34 SMT ones on the input/clock board and front panel board. I see 8 more M4's in the buffer circuity along with MELF diodes - anybody know what they are for? Are they local power supplies and I should replace them too?
