nekromantik
- Jul 30, 2009
whats the easiest way to get bass boost?
Paying for Viper or doing it via Fiio App EQ?
Settings->Wifi ->Advanced ->keep wifi on during sleep =alwaysYou're not the only one ... there seems to be a 15min Timer that is going to shut down WiFi ...
Experienced it while streaming from a website ...
But I did not find a way to avoid this so far ...
Thanks. Will play around with EQ. Wish there was a bass boost option like in Android apps.
Some folks are using ONKYO or Poweramp for more bass adjust.
I don't have Photoshop but the .jpeg file, as George said, was fetched from Google and there is one photo. I deleted the first one and downloaded another, same result. I even re-rip those flac again lest it was a problem with embedded artwork but still, same result. No matter it is named "cover.jpeg" or "folder.jpeg".
I could locate it in the file manager:
......but it can't be displayed when playing the music (the blue photo is the personalized one rather the one in the folder):
Nice, I tried to solder one of those TRRS plugs and they are way too small for my poor solder skill set. How about a photo of the plug with cap unscrewed to satisfy my curiosity.Still testing, but I finally built my cable to pair my X5iii to my Schiit Jotunheim.
Thanks Mate. It seems to me it was a problem with the file extension ".jpeg".
