Dimu
- May 7, 2016
Those radiators won't hurt but also likely won't make too much of a difference as you already have good airflow over the board. There are built in radiators with thermal vias in the board so having airflow should be sufficient to keep things in check.
I've got a configuration without hum using the power of heat shrink. I used just small pieces of heat shrink in the original cable and it obviously was not enough heat shrink so I wrapped the whole thing
Notice the wire is much longer than the old version and still no hum. I think drilling couple more holes at the rear wall and moving all four mosfets off the board is the next step for me. This should let the amp run comfortably without any airflow (that is after I figure out the mechanical work of fitting my power transformer in a way that will let the case close).
