wankski
- May 24, 2009
hmm, might have to try it.... do like the specs of the mk iv tho...
I was going to buy the DT880 600ohm until I read this thread: http://www.head-fi.org/forum/thread/506963/dt880-600ohm-bs
Reading that convinced me that there's a very small audible difference if any between the different impedances.
... I've learned that sometimes the people here just repeat what others have said without really listening to it.
There are inconsistencies in your statements.
Reading that convinced me that there's a very small audible difference if any between the different impedances. I ended up buying the 250 ohm after testing out a 32 ohm. I decided to go with the 250 ohm because it seems like it's Beyerdynamic's standard version and should work for most applications. After reading this message board and wasting my money... I've learned that sometimes the people here just repeat what others have said without really listening to it. Connecting my DT880 250 ohm to my MacBook Pro, the volume is adequate at the 2nd or 3rd little tick out of 16. So if you end up getting that one, you probably don't need an amp even though everyone claims that it's necessary.
Hey Zombie_X:
I read that you have the PHENIX G3, do you know how it compares to the Little Dot MKIII?
Or should I just go with a Head-Direct EF2 (amp + dac)
Sources being : Audigy2ZS or laptop (music), PS3 (movies/games) , XBox360 (games) , Zen Micro (music).
Bonus noob question : I have to do research but the USB in DAC in is not like an external sound card seen in Windows right?
Sorry for not replying sooner. I had the G3 and it was a great amp for the price. I have not heard the MKIII in a long time so I can not comment there.
The USB DAC would pop up as a USB device, like USB Speakers or something like that. That is what you were asking right?
Cool for the G3, but it is a tube amp so if I understand correctly would "color" the sound more than a SS. I also read that they're "not good good for electronica and/or gaming" since they are "slow". Is this related to some kind of micro delay in sound that would "break" the fast techno beats and also the sense of immersion while playing?
If this is the case that this would be another point for the 250's since decent/affordable amps for the 600's are almost all tubes. (max 200$ amp)
As for the USB DAC... yeah that was exactly my question)
I prefer the sound of solid state, which is far flatter and more accurate, but tube amps driver my higher impedance headphones much better.
Since you like Techno/Electronica, I find I can not recommend the G3 for you. I find it has great synergy with the 250Ohm DT990 (tames the treble and fills the mids), but it's a slower amp and won't work good for faster genres. I does work really well with acoustic music though!
Tube or SS? Also what do you use the HPs for (games, music types..) ?after building my amp though, it sounded a lot better.
