CoffeeCutie
https://3dwarehouse.sketchup.com/model.html?id=a31ee6df-5708-419b-94a0-15d64f2c1c7b
...So, we begin!
I am beginning my process of building a planar driver headphone, ideally in tandem with the electrostatic build. They share construction principles, but the ES driver requires a fairly expensive amp build- which will take extra time, cash, and thought. So the planar is up to bat first.
This is my planar v2 design. it employs a two 2x4 arrays, sized 1x1/4x1/4 inch each, encasing a membrane (such as saran wrap, kapton, mylar, the usuals) with a thin etch of RFI tape or otherwise very thin copper tape. I will 3d print these chassis and housing parts, because that is a tool I have easy access to. the wooden cup may require a CNC trip, because CNC'd cups are snazzy. The overall cost is low; the amp can be simple (simpler that is); the parts can be emulated with ebay-able and sometimes amazon-shippable items.
I am toying with the ES and dynamics too. Assuming I remember to write updates and don't unearth the possible fact "it can't be done" I may venture into these other operating principles too.
Happy Building!
...So, we begin!
Happy Building!
