Ciuvn
- Apr 26, 2013
I do not think it works that way. Only 1 side should be setup with OTG function. The other should be setup as a normal USB style connection. Yes, they can both be MicroUSB as that is how I've done it when I was using an external DAC.
^.^ You should try then!
if ok then you don't have to find the port with OTG to plug ^.^
