InsanityOne
- Jan 30, 2014
Hello Everyone,
My apologies for double posting, but I just had a quick question for those of you who use the Mini-M8 with a Desktop / Laptop PC as a source (USB). I followed all of the instructions to get it setup properly, I am using a dedicated USB 2.0 port on my laptop as well as Foobar2000 with the ASIO output component and the latest CEntrance Universal Driver. But for some reason, whenever I am listening to music and surfing the web I get weird audio skips and crackles when I'm loading webpages or switching tabs. But when I am doing nothing / very light tasks on my laptop I get ZERO skips / crackles what-so-ever. Any ideas?
P.S. - I am on a Windows 10 PC and I did follow CEntrances instructions for installing the driver on a Windows 10 PC.
P.P.S. - When doing zero / light tasks on the laptop I get ZERO skips / crackles when having the latency at 1ms via. the Driver Control Panel. But when doing more / heavy tasks on the laptop I even get skips with the latency at 20ms via. the Driver Control Panel.
Edit: Upon further inspection it appears that I cannot get any sound from Windows at all. Only from Foobar2000. Odd.
Edit2: Completely uninstalled / re-installed the driver and then Windows Audio worked but Foobar2000 reported "Playback Error: ASIO Buffers Could Not Be Created." Then Windows Audio stopped working again.
Edit 3: Windows Audio is not working due to Foobar2000 taking "exclusive" control of the audio outputs on the laptop due to the ASIO driver. This means that only Foobar2000 can transmit audio to the Mini-M8. Supposedly this "exclusivity" is supposed to stop (and allow Windows Audio) if you close Foobar2000 or reset its output back to default. But that doesn't solve the issue.
Thanks!
- InsanityOne
Thanks!
- InsanityOne
