Gediminas
- Jan 9, 2017
Does your unit also have a hint of white noise? (thanks)
Yes, at least mine does. I've contacted B&O and they replied with following message:
We can confirm that the BeoPlay A1 when it's turned ON (product indicator solid white) and no music is playing will output a very low noise. The noise can be heard if you move your ear very close to where the tweeter is located (a inch left from the leather band). When The BeoPlay A1 is OFF (product indicator is off) no noise from the speaker can be heard.
The "noise" heard is what we call "the noise floor" - which is a compromise between the maximum Sound Pressure Level (SPL) and audible noise in paused music Signal to Noise (S/N).
