oneplustwo
Member of the Trade
- Jan 27, 2009
My main motivation is mechanical actually. I was thinking about orienting the trafo vertically and bolting to a 1/4" thick piece of aluminum plate. (The mounting bolt is super beefy so I'm not worried about it... i think it's probably 1/2 or 5/8" diameter.) That plate would have 8 holes in it and would be bolted to the front panel with spacers to allow room for the on/off switch. This way, it can be supported directly by the handles/thick front panel without having to reinforce the bottom panel with a sub chassis or beefing up the brackets that hold the bottom to the heat sinks. This takes the stress off the bolts that hold front panel to the heat sinks as well. Also, I think it would make the front panel a little more interesting to have some large (maybe slightly recessed) socket head caps surrounding the on off switch. There is also a benefit in terms of layout since this reduces the footprint of the trafo. And finally, although there probably isn't much if any impact here, the two trafos would be working on orthogonal axis.
