Head-Fi.org › Forums › Equipment Forums › Headphones (full-size) › 22 headphones later...
New Posts  All Forums:Forum Nav:
post #1 of 11
Thread Starter
still havent found the perfect can for metal. still blows my mind that people recommend grado's for metal. bass is to weak and the hi's will make your brains leak out of your nostrils. seriously... what cans under $1000 are great for metal? like... strong kick drum with authority. a fun headphone. thanx
post #2 of 11
If only you looked a bit harder, you would've stumbled into this long, long discussion on the topic... smily_headphones1.gif
Headphones for Metal Music-Ultimate Solution
post #3 of 11
Thread Starter
that thread is all over the place. according to the op's graph chart... the fostex th600's are the best for metal but not one post mentions the headphones. weird...
Edited by Sargatanas - 7/5/14 at 1:22am
post #4 of 11
Grado SR325s. No matter what you think OP, they're still the best.
post #5 of 11
Thread Starter
And discontinued. Not an option even I wanted to try them. Grados hurt my skull. Do not like
post #6 of 11
325s/325is/325es/whatever.
If you were a real metalhead your head would hurt from headbanging not Grados anyway.
:D
post #7 of 11
Have you tried the lcd2? Nice mids and a solid low end.
Sennheiser hd600 is also the best jack of all trades value around imo. Could try one of those.
post #8 of 11
HE400i has a lot going for it. It has real drive, good soundstage, and the bass you want.
post #9 of 11
Thread Starter
No I haven't. I wonder which is a more fun headphone between the fostex 600 or the lcd2?
post #10 of 11
Fun is typically referred to as like an authoritative bass punch and sparkle up in the treble.  I do not have experience with the fostex 600, but I do with the previous Denon models they are similar too.  If the fostex 600 is anything like the denon d2000/5000/7000 then I would call it more fun than the lcd2.
post #11 of 11
I think the Fostex is more fun.    It might be what you are looking for
  Return Home
  Back to Forum: Headphones (full-size)
